Author Topic: Stereotype with TaggedValues doesn't work correctl  (Read 3676 times)
pspoenemann
« on: September 27, 2012, 04:34:38 pm »
I have a profile, that contains some stereotypes for objects with TaggedValues.
And I have QuickLinks, that will create new objects of one stereotype, when drawing a QuickLink from an existing object.
The new created object's dialog opened, before the TaggedValues are available.  The stereotype is set correctly. But no TaggedValues are visible.
Closing the property dialog and open it again shows all TaggedValues.
If I choose the object with stereotype from the toolbox, everything work as expected.
Peter
Re: Stereotype with TaggedValues doesn't work corr
« Reply #1 on: September 27, 2012, 09:13:46 pm »
Probably you need to qualify the stereotype in the QL with your profile name? I haven't done this, so you need to experiment and/or contact Sparx directly.
« Reply #2 on: September 28, 2012, 08:50:19 am »
This is a bug, already fixed for the next release. My recommended work-around is to go Tools > Options > Objects and switch off "Edit Object on New".
pspoenemann
« Reply #3 on: September 29, 2012, 04:19:31 pm »
Thank you for the info.
Waiting for the next release.
Peter
pspoenemann
« Reply #4 on: October 28, 2012, 01:07:53 am »
It is not really fixed in 10 Beta 1.  :(
The tagged values appeared now in the dialog, but the entered values will be cleared after leaving the new object dialog.
I send a formal bug report.
Peter
