Author Topic: connectorDestTag  (Read 2944 times)
rob.lancaster
connectorDestTag
« on: August 15, 2006, 01:09:22 am »
Hmm... Is there any more documentation on the use of %connectorDestTag:""% when using it generate code?
I'm trying to get the name of an Destination ?object? that a StateFlow connecter is pointing at... and I cannot get this working.
I can't work out the name of the tags that I should be using to get the name....
and the manual mentions "connectorDestElem*", but I', thinking these are un implemented, as the Template editor does not highlight the keywords.
Re: connectorDestTag
« Reply #1 on: August 15, 2006, 02:58:23 pm »
Maybe you should explain a bit more what you're after, and maybe some of what you've tried.  The name of the element at the destination end of a connector is accessible via connectorDestElemName.  (Which is highlighted in my editor by the way)  Additionally, all of the connector macros will only work if you are in a connector template.
