Author Topic: raquest -  (Read 3627 times)
brunogers
raquest -
« on: November 16, 2012, 03:12:41 am »
hello team,
with raquest 4.0 b103
i have two issues :
Major issues -
  While i write several tests to check a requirement, i cant update or modifiy items.
   error Message :
unexpected error occured.
(DAO.QueryDef[3075]
Syntax error (missig operator) in query epression
'Object_ID=21 and Test="Il existe une fonction, qui prévoit en cas de modification des finalités d'usage du service, d'informer le client des changements.' and TestClass=4'.)
Minor issu:
In raquest menu  : Tools - Local Option - fonts - Requirement detail
  If i change the font, it dosent affect the font of the Test menu. only the detail.
  It was suitable to affect the two items, to be adapt and readable easyier.
Thanks for yout help
Bruno
g.makulik
Re: raquest -
« Reply #1 on: November 16, 2012, 05:28:31 am »
Are you talking about raquest integration with EA?
Then you should send your issues to the provider of this solution (AddIn??).
Also note this is a user forum, not the official bug report site for EA. You can send an official bug report to Sparx Systems here: http://www.sparxsystems.com/support/bug_report.html
Günther
« Last Edit: November 16, 2012, 05:28:51 am by g.makulik »
Takeshi K
    • Sparx Systems Japan
Re: raquest -
« Reply #2 on: November 16, 2012, 08:16:03 am »
Thank you for your report, and I am sorry to for your inconvenience.
RaQuest is an Enterprise Architect's Add-in by Sparx Systems Japan. I will forward your report to our support team. If you need official response about these issues, please use the following form and report them.
https://www.sparxsystems.jp/en/inquiry.cgi
t-kouno
