Author Topic: No Inheritance from c++ interfaces  (Read 3534 times)
cliint3112
« on: November 16, 2012, 07:01:58 pm »
I have a pure virtual abstract interface foo and a class bar, thar inherits the interface. After Codegeneration, class bar does not have the methods of foo.
Have selected stereotype <<interface>> for foo and checked 'Generate methods for implemented interfaces' in Attribute Options
Greetings,
clint3112
Re: No Inheritance from c++ interfaces
« Reply #1 on: November 16, 2012, 07:14:12 pm »
Clint,
Are you sure that selecting <<interface>> stereotype is the correct way of working?
I think an Interface is not the same as a Class with stereotype <<interface>>. But I could be wrong of course.
cliint3112
« Reply #2 on: November 16, 2012, 07:23:14 pm »
Hi Geert,
never went to a training in EA but when you look at the stereotype enumeration, it's correct for an enum. So why shouldn't be interface the wrong stereotype for interfaces?
greetings,
clint3112
cliint3112
« Reply #3 on: November 16, 2012, 07:26:26 pm »
Okay, my fault. Choose class with stereotype interface and not interface with stereotype interface  ::)
« Reply #4 on: November 16, 2012, 07:27:34 pm »
Interface and Class are different metaclasses in UML (and EA).
So there's a difference between creating a Class with stereotype <<interface>> and creating an actual Interface.
The enumeration issue has been addresses in the current EA version 10 (beta). They are now two different metatypes as well (although EA keeps some backward compatibility for the stereotype <<enumeration>>.
Just try it with an actual interface and see if that works better.
