Author Topic: Import C-Code does't work for volatile in a typede  (Read 4802 times)
Helmut Ortmann
« on: October 01, 2012, 09:57:02 pm »
Import C-Code does't work for volatile in a typedef
all typedefs which have a volatile are completely ignored. E.g.:
typedef volatile int vbool_t;
No generation of a Class, no error message.
Thanks for your help.
Kind regards,
Helmut
g.makulik
Re: Import C-Code does't work for volatile in a ty
« Reply #1 on: November 17, 2012, 06:29:36 am »
Late answer, but anyway.
Does such a typedef really make sense, I thought the 'volatile' keyword should apply for particular instances of a type, not to the type itself (though the C compiler might accept such thing)?
Best regards,
Günther
Helmut Ortmann
« Reply #2 on: November 17, 2012, 05:40:18 pm »
Hi Günther,
your are right in saying that the volatile keyword makes only sense in the context of an instance. This is in fact true for all typedefs.
A good way of thinking of typedefs is to call them an Alias to have an easy to read definition of an instance / variable.
Besides, it is common practice in the realm of embedded to use such typedefs.
I sent a bug report to SPARX and two days later I got a *.xml file to fix the known problem.
Best regards,
Helmut
g.makulik
« Reply #3 on: November 18, 2012, 12:20:10 am »
Yeah I know, there are often silly things done in embedded realm if the compiler accepts it. The other way to place 'volatile' when declaring instances is still giving better readable intend IMHO.
I guess they fixed s.th. for the C parsing process. Can you tell what kind of XML that was and if the error was also fixed in the next standard version.
Best regards,
Günther
Helmut Ortmann
« Reply #4 on: November 19, 2012, 06:13:11 pm »
Hello Günther,
1. The bug is fixed in 10 Beta 2
2. *.xml file for MDG technology folder
<MDG.Technology version="1.0">
 <Documentation id="12093714" name="Fix Issue: 12093714" version="1.0" notes="Temporary workaround for issue 12093714, where C parsing fails on volatile"/>
<CodeModules>
<CodeModule language="C" notes="">
<CodeOptions>
 <CodeOption name="PrependGrammarDefinitions"> <fullType> ::= (<constOrVolatile>)* <nonEmptyType> <far> <optReferenceType> (<constOrVolatile>)* [<funcPtrExt>] | <fail>; <constOrVolatile> ::= "const" | "volatile"; </CodeOption>
 </CodeOptions>
 </CodeModule>
 </CodeModules>
 </MDG.Technology>
Kind regards,
Helmut
