Author Topic: crush because of nested class of a nested class  (Read 3398 times)
MREA
« on: November 28, 2012, 05:43:43 pm »
Hi
I found out why EA was crashing all the time while generating code!
The problem was if you have a structure like that
class
    |_struct
         |_ struct
          |_union
if the struct and the union are marked as nested, EA Crash while generating. If you delete all the nested links it work again!
should be fixed or am I the only one?
Support- Languages: German, English, French
g.makulik
Re: crush because of nested class of a nested clas
« Reply #1 on: November 29, 2012, 07:45:51 am »
I guess you want to have s.th. like this in the generated (C) code:
typedef struct
      struct Struct1_1
            int attr1;
            int attr2[4];
      }  Struct1_1;
      union Union1_1
            unsigned char attr1;
            unsigned char attr2[4];
      }  Union1_1;
      int attr1;
      int attr2;
}  Struct1;
I have achieved this reversed engineered model using the code from above within a class module named Class1.(h/c):
At least I've got no errors or EA crashes when newly generating or synchronizing from code or model.
Günther
« Last Edit: November 29, 2012, 07:56:53 am by g.makulik »
MREA
« Reply #2 on: November 29, 2012, 05:15:00 pm »
actually sth like this
class
      struct
            int attr1;
            int attr2[4];
      }  Struct1_1;
      union
      }  Union1_1;
      int attr1;
      int attr2;
« Last Edit: November 29, 2012, 05:15:41 pm by EAIFM »
g.makulik
« Reply #3 on: November 29, 2012, 07:27:05 pm »
I know that your code is also valid. But EA can't reverse engineer the contained structs without a name. They will be shown as <anonymous>.
Unfortunately forward code generation will also place <anonymous> as struct name then. May be it's possible to fix this in the code generaton templates.
Do you have legacy code you cannot change? Otherwise I would simply recommend giving the structs and unions a name.
Best regards,
Günther
