Author Topic: Font settings for ReportTemplate/Table of Contents  (Read 4951 times)
Patrick Julian
« on: November 20, 2012, 01:02:09 am »
Hello all,
in EA 9.1 I have an issue with the font formatting of the autogenerated table of contents for the RTF report. I apply a custom font in the template but when the placeholder gets rendered, Arial is used in the generated document anyway.
Does anyone have a solution? Is it just me or a known / fixed issue?
I have no possibility here to install the newest beta so I cannot check if this has been fixed in newer releases.
Cheers
Re: Font settings for ReportTemplate/Table of Cont
« Reply #1 on: November 20, 2012, 02:20:52 pm »
let me check, you
changed the ToC style (or styles) in normal.rtf using word outside of EA.
You updated your Resources | Document Templates | Global
EA template using "File Update Styles" or "Import"?
or you changed it using the RTF editor?
Patrick Julian
« Reply #2 on: December 20, 2012, 03:02:42 am »
Sorry for the late reply. I thought I had checked to be notified of answers but - I didn't, so I wasn't.
In fact, I did edit the style using the built-in RTF editor.
momochan
« Reply #3 on: December 20, 2012, 05:03:05 pm »
Hello
   I use EA9.3 and I got same problem with Thai fonts.
I cannot see custom fonts (Thai font) in built-in RTF editor
So I changed normal style in normal.rtf according to skiwi suggestion.
Then generate document and view via EA, it show correct font (Thai font).
But when I open file via window explorer with Microsoft Office 2010, it display another font (not my custom font) in the generated document.
While I open the same file with LibreOffice it display corrected-font.
Does anyone have any solution?
« Last Edit: December 20, 2012, 07:41:56 pm by somsak.chan »
