Author Topic: Missing name column in class operations detail  (Read 4780 times)
exquisitus
« on: January 12, 2013, 12:17:18 am »
In EA10 in the class operation dialog the name column is missing. Does anyone have an explanation for this?
Thanks.
PaulV
Re: Missing name column in class operations detail
« Reply #1 on: January 13, 2013, 05:24:05 am »
Thanks.
Do you mean this dialog?
"Name" column is marked - I can see it.
exquisitus
« Reply #2 on: January 13, 2013, 05:45:52 am »
Hi Paul
Perfectly right, yes. By the way, how did you post the image? I prepared one to illustrate the posting but could not find an attachment link.
PaulV
« Reply #3 on: January 14, 2013, 01:42:37 am »
Hi Paul
I place the image file on a hosting and its URL into img-tag.
[img]http://img4.fotos-hochladen.net/uploads/ea10opnameokvbyt74rx8m.gif[/img]
« Last Edit: January 14, 2013, 01:44:16 am by PaulV »
exquisitus
« Reply #4 on: January 14, 2013, 03:25:25 am »
Hi Paul
Meanwhile I found the reason for the missing header column. The column headings are draggable. Apparently I removed the column by accident. A right click on the header row pops up a context menu from which one can choose the columns to be displayed (Field Chooser). I am not sure if this is mentioned in the user guide.
Anyway, thanks four your help and the hint regarding image posting (see below!)
PaulV
« Reply #5 on: January 14, 2013, 03:44:05 am »
Hi Paul
Meanwhile I found the reason for the missing header column. The column headings are draggable. Apparently I removed the column by accident... I am not sure if this is mentioned in the user guide.
I guess this is a standard behaviour of this Windows control; yes, it can sometimes surprise. But such behaviour doesn't belong definitely to the EA user guide.
« Last Edit: January 14, 2013, 03:45:07 am by PaulV »
