Author Topic: EA on windows server 2008 R2  (Read 4446 times)
foldedwave
« on: January 18, 2013, 10:23:45 pm »
I currently use EA at work on a development vm running windows server 2008r2. I have come across a fairly serious issue with this setup though. When I import source into EA, it looks as though the import has been successful but when you look into each of the operation properties, you can see that the initial behaviour is empty - obviously this causes issues when you then try to regenerate the code from EA.
Can anyone confirm this? Is there a workaround?
Re: EA on windows server 2008 R2
« Reply #1 on: January 21, 2013, 08:22:36 am »
Tools | Options | Source Code Engineering | Attribute/Operations | Include method bodies in model when reverse engineering.
It's off by default and you want it on.
