Author Topic: Error Transfering the repository to MySQL  (Read 5231 times)
nits
« on: February 12, 2013, 05:21:57 am »
We just received the new EA version 10.  Previously in older version I was able to transfer the repository to MySQL database. Now with the new version the transfer does starts but hangs after some time. And eventually gets "Not responding" error from EA. Does anyone has this issue or some solution for it? I checked the windows log and I get the following error description:
The program EA.exe version 10.0.0.1006 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
 Process ID: f20
 Start Time: 01ce086a067ccb0b
 Termination Time: 41
 Application Path: C:\Program Files (x86)\Sparx Systems\EA\EA.exe
 Report Id: db181fb0-745e-11e2-be1d-74e5434d881c
Re: Error Transfering the repository to MySQL
« Reply #1 on: February 12, 2013, 06:06:16 am »
Looks like a driver problem (Windoze is a design error...). Try installing the 32 bit driver which is , I guess, required by EA.
