Author Topic: Image rendering  (Read 4393 times)
Patrick Julian
Image rendering
« on: February 19, 2013, 11:31:13 pm »
Hello everyone,
after inserting a JPG image from disk into an EA diagram, I cannot get it rendered properly: EA's antialiasing (from the enhanced-1 renderer defined in tools > options > diagrams > appearance) seems to have no effect at all. Apparently it is just applied on connectors (?).
What is more, I resized the image in an external editing program as to avoid EA's resize - which I guess is just as imperfect as image scaling in an old-school browser. However, I cannot set the (externally modified) image to be scaled to exactly 100% altough that might help to avoid the pixelation artifacts  caused by EA's faulty attempt of resizing.
This is a problem especially if you have text in a screenshot that you'd like to include into a diagram. The text becomes pretty much illegible.
Am I missing a cool feature to work around this?
Thanks!
Patrick
P.S.: EA v9.1, Win7
« Last Edit: February 19, 2013, 11:32:47 pm by observer »
Re: Image rendering
« Reply #1 on: February 20, 2013, 12:18:08 am »
I just inserted a png and a jpg and they scaled immediately to 100% clearly readable. Maybe you´re playing with the zoom slider bottom right. That will introduce the effect you are seeing.
Patrick Julian
Re: Image rendering
« Reply #2 on: February 20, 2013, 01:27:27 am »
that was my first thought and I have reset it before asking using the "set to 100%" in the Pan & Zoom view.
Just now I found out another option in the same settings dialog seems to have caused the effect. After resetting "scale view by" to "0%" now everything seems back to normal.
However, after manually resizing a picture you cannot reset it to its original size, right?
Re: Image rendering
« Reply #3 on: February 20, 2013, 02:52:54 am »
I used the zoom in/out menu without problem. There's a second slider in the Pan&Zoom window which sets the zoom to something different than the even steps from the menu options. But using the Zoom to 100% solves the issue.
Likely the rendering for the printer is not such a problem since the resolution is much finer (except you maybe have a Retina display).
