Author Topic: Version 3.60 - Build 649 Released  (Read 22315 times)
sparks
« on: October 24, 2003, 12:28:51 am »
Changes and Fixes in Version 3.60 - build 649
Extended support for Composite Elements to Class, Object, Use Case etc.
     - Can be set from context menu option on diagram element
     - Automatically adds a child diagram to the Composite Element
     - Adds a small icon to the lower right corner indicating Composite
     - Double click on Composite Element will open the child default diagram
Added automation support for composite elements - Element now has an Elements and a Diagrams collection
Added App object to EA automation interface
EA Type Library updated to version 2.02.
Fixed issue with source code editor prompting to save file after code generation
Changed package generation to ignore existing file paths by default, when auto generating directory structure
When running EA from external automation client, main windoww is now automatically hidden
When running EA from external automation client, add-ins are prevented from loading
Also added ability to retrieve App Object from the "Running Objects" table using constructs such as VB's GetObject() function. (see Help file for more information)
Added ability to add and work with  Nested Version Control packages in the Project Browser (ie. children of Version Controlled packages may now be Version Controlled as well.
Added Constraint Status Types Dialog & support code to provide user-customisable constraint status types.
Fixed problem with loss of Keyboard mappings when switching between Visual Layouts
Fixed problem with sequence diagrams when "New" message is preceded by a Return message to an other object
Fixed problem with diagram not being marked dirty when relation suppressed thru docked relations window
Re-worked Project/Issues dialog to be more in keeping with the System/Issues dialog
Fixed issue with Source Editor when using Local Paths as part of the filename
Allowed diagrams to be placed under Root node in project browser
Fixed error when deleting tablespace names
Added support for color and border style using the Format toolbar when editing Note elements
Modified System Issue dialog to replace "Save" with "Apply" and retain current record after saving
Corrected a couple of minor XSD generation issues
Disabled Version Control "Change User" button for Jalinda Igloo, which does not support the function.
Changed route behaviour for Association classes so that it routes in the user-specified default mode.
Added default property operation note values to new property creations (attribute notes)
Fixed diagram draw behaviour logic that refreshes a lollipop name of a realised interface when the interface's name is modified
Fixed Issue Dialog problem that did not set edit fields as dirty when user entered white space (space).
Fixed Property checkbox behaviour for Attribute Edit dialog that erroneously showed properties as unchecked
Linked display of Delphi Tagged Values for Properties to visibility of Operations (hiding one hides the other)
