Author Topic: include section not valide after round-trip (rever  (Read 4222 times)
LTO
« on: August 24, 2006, 08:11:38 am »
I reverse a file containing a class definition in C# (see attached file). The reverse process gets info for code source such as method defintion, fields, ... I want to generate the file after modeling to synchronize data.
The synchronization with "replace existing file if exist" option don't generate proper import section.
Can you help me ?
Original Import section :
using System;
using System.Collections;
using System.Collections.Generic;
using System.Reflection;
using System.Text;
using EAC.Transversal;
using EAC.Data.PersistEntity.ADM;
using EAC.Data.PersistEntity.AGE;
using EAC.Data.PersistEntity.ARBO;
using EAC.Data.PersistEntity.GC;
using EAC.Data.PersistEntity.VITI;
Generated Import section :
using System;
using ADM;
Laurens TENDERO
        Team Manager - Neotic SA
Re: include section not valide after round-trip (r
« Reply #1 on: August 24, 2006, 03:09:38 pm »
The using statements that EA is generating is for all the classes that EA knows that your class needs.  (Because you have a generalization, attribute, parameter or method return type.)
The first recommendation for this would be to ensure that as many of the used libraries etc. as possible exist in your model before reverse engineering your source.  This will help EA to create the right relationships.
However, even then EA doesn't know about the types that are only used in your method bodies.  You can tell EA to include these entries by adding them into the field in the code generation dialog.  (Ctrl+G on a single class).
LTO
« Reply #2 on: August 25, 2006, 12:18:06 am »
Thank you, this help me.  :D
But can I reverse include files in the file imports/header section.
Laurens TENDERO
« Reply #3 on: August 27, 2006, 03:15:22 pm »
No, there is currently no option to do that.
LTO
« Reply #4 on: August 28, 2006, 12:08:43 am »
this option really miss to do round-trip engeenering.  :(
Laurens TENDERO
