Author Topic: 856 RTF editor input methods  (Read 15468 times)
« on: May 28, 2010, 09:40:25 am »
I have discovered that the RTF editor fails to work correctly with the New Zealand M[ch257]ori Keyboard.
This also apples to some (but not all) notes fields.
When I paste "Word [ch257][ch275][ch299][ch333][ch363]." into an RTF document, or some notes fields it appears to be saved correctly, yet when entered from the keyboard the characters are incorrect.
Has anyone else had this issue with Unicode?
nutria
Re: 856 RTF editor input methods
« Reply #1 on: June 02, 2010, 12:49:26 am »
I have the same problem (with other language).
I know that half year ago we resolve this problem ... but I don't remember how.. .
I have this problem when I'm writting sth in field "notes" and save. after that my polish sings are not-polish...
nutria
« Reply #2 on: June 02, 2010, 01:23:42 am »
I resolved my problem.
My problem was with english-Windows-version.
to resolve my problem I done:
Control Panel->"Regional and Language Options" ->"Advanced" ->"Language for non-unicode programs" -> "Select a language to match the language version of the non-Unicode programs you want to use:" There I choose "Polish"
I think, that you must choose sht with"New Zealand M[ch257]ori Keyboard"
« Reply #3 on: June 02, 2010, 06:36:08 am »
Thankyou.
Currently my setting is English (New Zealand).
Unfortunately there is no option for New Zealand M[ch257]ori, or M[ch257]ori
« Reply #4 on: June 02, 2010, 08:53:33 am »
Nutria,
If that's the case, you are probably not using a JET 4 database.  I would recommend getting the JET 4 base model from the Sparx Systems website and transferring your model into it.
Please send a bug report into Sparx Systems about M[ch257]ori input so that we can investigate it properly.
« Reply #5 on: June 02, 2010, 09:16:04 am »
The database in which this is occurring is SQL Server 2005.
I will file a bug report.
nutria
« Reply #6 on: June 02, 2010, 05:10:32 pm »
hmm...  How can I do it?
« Last Edit: June 02, 2010, 05:11:15 pm by nutria »
« Reply #7 on: June 03, 2010, 06:49:53 am »
I can't find this information on the Sparx website (Sparxians - please add to FAQ),
but see this post
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1242809991/3#3
nutria
« Reply #8 on: June 04, 2010, 07:51:57 pm »
but see this post
Thanks.
Unfortunately it dasn't work in my EA :(
« Last Edit: June 04, 2010, 07:52:30 pm by nutria »
« Reply #9 on: August 04, 2010, 10:40:30 am »
It wasn't mentioned in the release notes, but in build 860 it seems like the handling of unicode (in my case characters with macrons) has been improved.
The issues reported (but not the spell checker) appear to have been fixed
« Reply #10 on: August 04, 2010, 02:47:07 pm »
It was fixed in 858 and was described by the following release notes.
Note Editors updated to improve handling of lists containing line breaks and character sets using the extended ASCII range.
« Reply #11 on: August 05, 2010, 06:41:36 am »
Well that shows how often I maintain or enter unicode!
However I now note that in the properties of a custom diagram neither the Name or Note retain (it can be entered) a unicode character (in this case "[ch257]")
Also in the note (but not the name) when I enter "[ch257]" I get "â", although  "[ch257]" can be pasted in.
Should be
Using a SQL Server repository. Unlock diagram, make change, lock diagram. Reload repository. Gone!
« Last Edit: August 05, 2010, 06:45:13 am by skiwi »
« Reply #12 on: August 05, 2010, 06:47:22 am »
True I overlooked that, but this is where it would be good customer service if
  • reporting customer's were notified of the fix
  • all bug reports, status, and fixes were visible to all customers
« Reply #13 on: August 10, 2010, 02:49:48 pm »
I have reported this as a bug.
Note we are using SQL Server 2005 for our repository.
We use Latin1_General_CI_AS collation setting.
As far as I can see as EA string fields are unicode (ntext, nvarchar), and all the tables and columns have the same collating sequence (as above).
« Reply #14 on: August 12, 2010, 07:46:11 am »
Here is an example (in 861) where using the same sequence of keystrokes (`a) in a name field, and a note field
gives a different result.
See the two highlighted text instances.
« Last Edit: August 12, 2010, 07:47:39 am by skiwi »
