Author Topic: Document Generation Activity Diagram  (Read 3006 times)
Marianne
« on: April 22, 2013, 10:41:49 pm »
Is the following correct?
If you add an activity to an object (requirement, use case,...) with an activity diagram, you can only add the activity diagram in your documentation (with document generation) by dragging it out of the activity and dropping it at the highest level in the object.
Doesn't work  :-[:
* my object
** my activity
*** my activity diagram
Works:
* my object
** my activity
Can I tweak my template to have the default working too?
Thanks!
Marianne
Re: Document Generation Activity Diagram
« Reply #1 on: April 24, 2013, 08:23:07 am »
Just make sure the child-element section is empty. That allows it to recursively use the element section. Which includes the diagram subsection.
