Author Topic: Quick Linker  (Read 6107 times)
Quick Linker
« on: May 06, 2013, 08:26:30 pm »
I wonder if someone else has the same experience or whether this is just a hick-up with my VM: When you create an element by pressing the space bar on a diagram you see the quick-linker icon (the little arrow), but you can't use it. You need to click once again onto the new element in order to be able to use the quick-linker. For me that is very confusing as often I want to connect the new element with another one. And then the click runs into the void and nothing happens.
Paulus
Re: Quick Linker
« Reply #1 on: May 07, 2013, 05:40:00 am »
No (using EA 10 build 1006 in Virtualbox 4.2.8 with Guest additions)
Re: Quick Linker
« Reply #2 on: May 07, 2013, 06:01:19 am »
No what? No, not that experience. Or no, does not work either?
It works correct with the diagram toolbox (drag'n'drop) , but not when using the space bar to open the context menu.
Re: Quick Linker
« Reply #3 on: May 07, 2013, 09:41:56 am »
When you create an element from the spacebar context menu, EA puts keyboard focus in the newly created element's name. I'd say that's correct: the first thing you're going to want to do on creating a new element is name it.
Re: Quick Linker
« Reply #4 on: May 07, 2013, 10:00:14 am »
Ehrm, what? If I create an element via blank space menu or via dragging it from the diagram toolbox takes me through the same workflow: properties are opened, I can modify and then save. Then I see the same picture: the new element, framed (selected) with the tools for quick-linker and painter. But in the first case these tools do not work unlike in the second case.
« Last Edit: May 07, 2013, 10:01:18 am by qwerty »
Re: Quick Linker
« Reply #5 on: May 07, 2013, 10:16:11 am »
Ehrm, what? If I create an element via blank space menu or via dragging it from the diagram toolbox takes me through the same workflow: [highlight]properties are opened[/highlight], I can modify and then save. Then I see the same picture: the new element, framed (selected) with the tools for quick-linker and painter. But in the first case these tools do not work unlike in the second case.
Ah, you have "Edit Object on New" selected. Different ball game!
Re: Quick Linker
« Reply #6 on: May 07, 2013, 10:30:37 am »
I have (although not remembering having it set). But then, is the behavior inconsistent? And should I report a bug?
Paulus
Re: Quick Linker
« Reply #7 on: May 07, 2013, 03:57:00 pm »
No as a response to your question 'I wonder if someone else has the same experience or whether this is just a hick-up with my VM'... so imo what you see is not a bug in EA, might still be a version or a configuration issue though.
Re: Quick Linker
« Reply #8 on: May 07, 2013, 05:57:17 pm »
Thanks Paulus. However, the issue is due to the different behavior after setting Edit on New. Probably I did set this option ages ago and each re-install preserves it. I will a report a bug.
