Author Topic: RTF script fragment not called from automation  (Read 4361 times)
Uffe
« on: May 06, 2013, 11:51:55 pm »
It seems that when you're creating an RTF document through the automation interface, any template fragments which themselves invoke scripts are not called. SQL fragments are called just fine.
I have also verified that the exact same "top" template calls the fragments correctly when invoked through F8 on the exact same element.
As previously documented (http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1366215976), I can't use SQL fragments because they mangle the formatting.
Am I missing something here?
/Uffe
Uffe
Re: RTF script fragment not called from automation
« Reply #1 on: May 07, 2013, 08:33:41 pm »
Oh, and by the way: headers aren't generated either. Same result: no header generated when called from the automation interface, header generated when invoked through F8 (same template, same element).
I haven't tried footers, because somehow it doesn't quite feel as if performing basic functional testing on EA is my job.  >:(
Dermot
« Reply #2 on: May 08, 2013, 03:09:16 pm »
Please lodge these issues via the support email via the links below and include zipped examples for replication.
Uffe
« Reply #3 on: May 10, 2013, 05:28:58 pm »
This has been verified as an Issue - the Issue Number is: 13055290.
