Author Topic: Behaviour Parameters default value  (Read 4202 times)
JensG
« on: May 11, 2013, 08:46:59 am »
I'm new to EA and (still) running the Trial.
According to the docs and according to the template for "WorkFlowScript", the default value for a behaviour property should be accessible through
$sValue = %EASL_GET("Property", $GUID, "Value")%
%if $sValue!=""%
"=" $sValue
%endIf%
However, None of my tries to convince the C# template to generate default values for arguments did succeed: The returned value is always empty. After looking for a working example I found the above mentioned "WorkFlowScript" template. Interestingly, this one did not succeed either.
So I'm starting to think whether this may actually a bug, may it be in the EA code or in the documentation.
Any opinions, hints or helpful pointers?
JensG
Re: Behaviour Parameters default value
« Reply #1 on: May 15, 2013, 07:18:40 am »
Wow, what an overwhelming response. Is my question really that special and complicated? Maybe I should try on http://stackoverflow.com instead?
« Reply #2 on: May 15, 2013, 09:20:28 am »
Sure, or you could contact Sparx Support using the link at the bottom of this page.
JensG
« Reply #3 on: May 17, 2013, 06:12:54 am »
Sorry, my fault. I took  the "Forums" link listed under "Support" at the bottom of the page for something that was actually intended to be used for Support. Stupid me.
