Author Topic: No BPEL context menu on BPEL Process Shape  (Read 3841 times)
james.kinneavy
« on: May 22, 2013, 11:42:57 pm »
I created a BPEL model and per the instructions at http://www.sparxsystems.com/enterprise_architect_user_guide/modeling_languages/generate_bpel.html: "Right-click on the BPEL Process element and select the BPEL | Generate BPEL context menu option. The Generate BPEL dialog displays"
I see no such menu and I've explored quite thoroughly the system menus.  Did this feature get deprecated?
RoyC
  • Read The Help!
Re: No BPEL context menu on BPEL Process Shape
« Reply #1 on: May 23, 2013, 09:45:26 am »
What release of EA are you using, and which BPEL Profile - 1.1 or 2.0? The Help link you provided went to the introductory page of the EA Help as a whole, in a rather old version. There are a couple of things that might be happening, but they depend of the versions in use.
Best Regards, Roy
james.kinneavy
« Reply #2 on: May 23, 2013, 11:42:59 pm »
Latest version of EA (10.0.1007).  BPMN Profile 2.0.  While I do see I can publish to bpmn 2.0 xml (Extensions >> Publish), I can find no export or publish for BPEL.
Thank you for your reply.
james.kinneavy
« Reply #3 on: May 23, 2013, 11:56:45 pm »
I believe I can answer my own question.  BPEL generation is a feature of the business & software engineering edition (or ultimate).
