Author Topic: Use of local path for XML Schema (XSD) generation  (Read 3516 times)
Eric Bourlon
« on: July 19, 2013, 10:02:43 pm »
I am using EA to model XML schema.
As property of the schema you can define the 'schema file'.
This value is used as file path and name when generating the xsd.
As multiple users are sharing this model, I would like to set a local path Id in this field like %XSD_PATH% so that each user can define the root path where to generate the XSD on his local machine.
But this does not seem to work.
When I set something like %XSD_PATH% in the schema file field, the writing of the XSD file fails.
Does anybody have a solution for this or find a way to circumvent this?
Eric Bourlon
