Author Topic: I have problems for reverse engineering in C/C++  (Read 6446 times)
kkakkung11
« on: July 23, 2013, 05:03:05 pm »
I've been performing a project related with reverse engineering using Enterprise Architect tool. But, it occurs unknown errors when I perform reverse engineering in C/C++ language. the error logs are followed:
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\7z\7zDecode.cpp  on line 91.  Unexpected symbol: *
You may need to define a language macro.
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\7z\7zEncode.h  on line 36.  Unexpected symbol: *
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\7z\7zHandler.h  on line 46.  Unexpected symbol: public
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\7z\7zIn.h  on line 210.  Unexpected symbol: baseOffset
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\7z\7zOut.h  on line 103.  Unexpected symbol: &
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\7z\7zUpdate.h  on line 74.  Unexpected symbol: *
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Cab\CabBlockInStream.h  on line 37.  Unexpected symbol: void
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Cab\CabHandler.h  on line 22.  Unexpected symbol: private
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Chm\ChmHandler.h  on line 22.  Unexpected symbol: private
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Chm\ChmHeader.cpp  on line 14.  Unexpected symbol: {
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Chm\ChmIn.h  on line 208.  Unexpected symbol: PURE
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Com\ComHandler.h  on line 23.  Unexpected symbol: STDMETHOD
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Common\CoderMixer2MT.h  on line 59.  Unexpected symbol: ISequentialInStream
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Common\CoderMixer2ST.h  on line 43.  Unexpected symbol: GetInStream
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Common\CoderMixerMT.h  on line 50.  Unexpected symbol: ISequentialInStream
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Common\CrossThreadProgress.h  on line 34.  Unexpected symbol: const
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Common\DummyOutStream.h  on line 20.  Unexpected symbol: const
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Common\InStreamWithCRC.h  on line 19.  Unexpected symbol: void
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Common\OutStreamWithCRC.h  on line 22.  Unexpected symbol: const
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Common\OutStreamWithSha1.h  on line 22.  Unexpected symbol: const
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Hfs\HfsHandler.h  on line 22.  Unexpected symbol: }
There was an error parsing C:\Users\soo\Desktop\7z920\7zip\Archive\Iso\IsoHandler.h  on line 25.  Unexpected symbol: STDMETHOD
Checking error logs, I think most of error was generated by codes to be processed by preprocessor, for example, "#define", "#ifdef" and so on.
How can I solve this problems ? can the Enterprise Architect reverse codes to be processed by preprocessor ?
I have one more question.
when a file generated an error in a certain line during reversing, I found that Enterprise Architect don't process after that error line in that file.
is there a function that can process continuously that file with skipping that error line ?
SomersetGraham
Re: I have problems for reverse engineering in C/C
« Reply #1 on: July 23, 2013, 06:07:16 pm »
Hi
If your code contains macros you can tell EA to ignore these.
For EA V10 the dialog you need is under Settings->Language Macros.
Without seeing your code it is hard to see what is causing your errors.
Using V12
kkakkung11
« Reply #2 on: July 23, 2013, 06:12:59 pm »
as you told, I can configurate in Settings->Language Macros. but,
for example,
if I define as
#define MACRO(a,b) function(c,d)
the error is not generated in that line. BUT,
the files that MACRO(a,b) is used occur error....
SomersetGraham
« Reply #3 on: July 23, 2013, 07:00:53 pm »
Hi
How did you add the macro definition in EA -
For your example you need to add it as MACRO()
Using V12
kkakkung11
« Reply #4 on: July 23, 2013, 07:25:29 pm »
Hi, thank you for your reply. your solution is good. but..
I'm measuring the opensource.
in them, there are so many macros, so, I can't add them all.. right?
is there any other solution ?....
SomersetGraham
« Reply #5 on: July 23, 2013, 07:44:57 pm »
I guess you could add them all, but it may be a little time consuming.
I am using Qt framework and to reverse engineer the files that I wanted to use, I made local copies and commented out the lines containing the macros. However, this wont work if you want to regenerate the source files.
Sorry not be be more help
Using V12
g.makulik
« Reply #6 on: July 24, 2013, 06:09:50 am »
If you want to reverse engineer the source without any errors, you'll need to set them up.
Another option might be preprocessing the code first, and reverse engineer the preprocessed C++ code.
Günther
