Author Topic: rtf fragments destroy content of operations  (Read 3240 times)
Helmut Ortmann
« on: July 29, 2013, 07:09:01 pm »
I created a document by copying it from the basic template. Everything runs fine.
The I added in the template: Insert Template (I used a SPARX example template to add)
After adding the template the attributes- and operation content shows only the field names instead of the field values.
Connectors on the other hand are ok.
The behavior is independant of the inserted template and of the position in the document template. I can also use other document templates. The same behavior.
EA: 1008
Thanks for your help,
Helmut
