Author Topic: Ran out of memory during rtf as PDF generating  (Read 4028 times)
Helmut Ortmann
« on: August 07, 2013, 05:54:13 pm »
if I generate large RTF documents as *.PDF the following happens:
  • Pop Up: Ran out of memory
  • Parts of the document are missing
  • In short no useful PDF document
The exact behavior differs from PC to PC.
It's easy to reproduce:
Try to document the whole EA example model as PDF. One PC runs out of merory. The other genereted without error message but parts of the documentation are missing in PDF.
I found the error message in the forum. No solution or workaround.
If I generate it as *.rtf it works fine.
Helmut
Re: Ran out of memory during rtf as PDF generating
« Reply #1 on: August 07, 2013, 06:08:38 pm »
I guess the workaround is to generate the RTF, open it in MSWord (other another RTF/PDF compatible tool) and save it as PDF from there.
Helmut Ortmann
« Reply #2 on: August 07, 2013, 07:58:54 pm »
Hello Geert,
thanks. The workaround works. The drawback is that in the *.pdf file the bookmarks are missing.
Helmut
