Author Topic: MySQL version problem: "Partition" is now reserved  (Read 5987 times)
Rhys Lewis
« on: February 25, 2013, 04:13:03 pm »
From version 5.6 of MySQL the word "Partition" is a reserved word - see here: http://dev.mysql.com/doc/refman/5.6/en/reserved-words.html compared to http://dev.mysql.com/doc/refman/5.5/en/reserved-words.html
Unfortunately the table t_xref has a column called "Partition", so whenever you interact with a diagram in a model that is hosted on a MySQL database that is version 5.6 you will get an SQL error as it doesn't recognise Partition as a column name unless it is quoted.
Any chance you could go through and quote all those SQL statements?
Re: MySQL version problem: "Partition" is now rese
« Reply #1 on: February 25, 2013, 07:56:58 pm »
I hope you've sent this to Sparx as well, because we (EA - users) can't help you much with this.
You can use the Report a buglinks on the bottom of the page.
« Reply #2 on: February 25, 2013, 08:58:46 pm »
There's PILE of columns in various tables that will break some database technologies.
I recall trying to setup EA many years ago for an unsupported RDBMS  and being shocked at the number of column names that were reserved words.
g.makulik
« Reply #3 on: February 26, 2013, 06:26:28 am »
Maybe this could be solved with a MySQL adapted database scheme and an 'alias' for the particular column names (calling in qwerty ...)?
Just my 0.02 EUR,
Günther
« Reply #4 on: February 26, 2013, 08:31:49 am »
Unfortunately I'm not a DBA, so I'm out :-[
Rhys Lewis
« Reply #5 on: February 26, 2013, 10:37:37 am »
I emailed it to Sparx yesterday, so I assume they are looking at it.
The workaround is to use version 5.5 or below.
Ian Mitchell
« Reply #6 on: August 08, 2013, 08:52:27 pm »
This is also a problem for me. Any chance of Sparx looking at this?
I thought that the Sparx devs mostly use MySQL: how are they managing this ?
There should at least be a warning in BIG LETTERS that more recent versions of mySQL are not supported by EA. I wasted a day discovering this....
www.eaDocX.com
www.theartfulmodeller.com
« Reply #7 on: August 09, 2013, 08:32:17 am »
We were made aware of this problem recently and have support for 5.6 in the works and it will be included in a future version.
In the mean time I would recommend using 5.5 or below.
