Author Topic: Search & modify object error  (Read 3505 times)
RobVDSS
« on: August 09, 2013, 11:20:42 pm »
The Sparx  software stops responding when modifying the field of an object after that object has been selected from a search.
When attempting to perform a search and modify the attributes of an object I receive an error. I first perform a search and receive search results. From the results, I then select an object to add, modify or delete information to the Name or Notes fields. When the OK button is selected the software stops responding and the error message below occurs.
___ :-?
The instruction at 0x72006100 referenced memory at 0x72006100. The memory could not be read.
Click OK to terminate the program
Click Cancel to debug the program
Re: Search & modify object error
« Reply #1 on: August 10, 2013, 12:20:19 am »
You should report that as bug to Sparx. Use the link bottom right.
