Author Topic: No menu entry for Schema Generation  (Read 3542 times)
Matze
« on: August 15, 2013, 05:46:53 pm »
I installed the EA Professional Version 10.0.1008 and face the following issue:
I open a project that was created by another colleagues some time ago with a previous version of EA. It consists of a UML class diagram and I want to generate a XML schema out of the classes. I found several documents (e.g. http://www.sparxsystems.com/resources/xml_schema_generation.html). But I don’t see the menu entry Generate XML Schema in the Project menu entry.
Other documents say that the schema generation is an entry within the tools menu, but again no menu entry in my installation found.
Do I miss something?
Any advice would be appreciated.
Helmut Ortmann
Re: No menu entry for Schema Generation
« Reply #1 on: August 15, 2013, 08:01:14 pm »
check View, Workspaces and Commands. Make sure that all commands are enabled.
Helmut
Matze
« Reply #2 on: August 15, 2013, 08:15:11 pm »
I did that already, but it didn't work. So I uninstalled the progamm, deleted the local application data and reinstalled it again. Now did I select all commands and yes it is working.
