Author Topic: C++ codegen error for ptr paramter of method  (Read 4714 times)
Kenny
« on: September 08, 2013, 09:55:10 pm »
I want to generate c++ code from a class diagram. But when I tried to set the type of a parameter of a method to pointer, the code generation enginee reported an error:
Unexpected symbol: *
Code generation failed.
I tried the following variants in the parameter field:
a: unsigned int* (error)
a*: unsigned int (good, but the generated code is not what I expected.)
*a: unsigned int (error)
Thanks in advance.
/Kai
g.makulik
Re: C++ codegen error for ptr paramter of method
« Reply #1 on: September 09, 2013, 04:54:59 am »
Did you try using the parameter editor for this? I've noticed that parsing plain UML op parameter syntax might fail, while specifiying types with the parametr editor works.
Günther
Kenny
« Reply #2 on: September 09, 2013, 05:57:34 pm »
Günther
yes, I did try to use the parameter editor to enter the parameters. The problem occurred when I tried to generate to c++ code. To my suprise, I tried to use the reverse engineering to import a piece of c++ code that contains also the pointer paramter in the method and then generate the c++ code. It worked very well. By looking at the operation field, the parameter has type "bool*". My original model looks the same as it. It is really strange that EA cannot handle my code, but it can handle the imported code. I must have missed some points.
Thanks.
/Kai
