Author Topic: Classifier as attribute type  (Read 5067 times)
Uffe
« on: October 29, 2013, 06:09:38 pm »
Hi!
If you select a classifier as the type of an attribute, EA does two things: it writes the classifier's name into the attribute's type (which is shown in diagrams), and it stores a reference to the classifier's object ID in t_attribute.Classifier.
If you then change the classifier's name, the attribute type is not updated to reflect this. Is there a reason for this? It would make more sense to me if the attribute type reflected the classifier's name.
Cheers,
/Uffe
Re: Classifier as attribute type
« Reply #1 on: October 30, 2013, 08:55:18 am »
It is doing it for me, but I did see one instance where it didn't appear to initially.
« Reply #2 on: October 30, 2013, 09:07:30 am »
Reproduced here. It only seems to be a problem with newly created classes/attributes.
« Last Edit: October 30, 2013, 09:11:57 am by KP »
Uffe
« Reply #3 on: October 30, 2013, 05:45:59 pm »
Thanks guys. A timing issue? Ouchie...
Would you like me to file it as a bug report?
/U
« Reply #4 on: October 31, 2013, 08:44:18 am »
Yes please. It'll get a higher priority than if I report it ;)
« Reply #5 on: October 31, 2013, 09:53:36 am »
Just for the records: will the priority increase if multiple users report the same issue?
