Author Topic: Version 3.60 - Build 651 Released  (Read 22730 times)
sparks
« on: November 04, 2003, 05:43:00 pm »
Changes and Fixes in Version 3.60 - build 651
Support for PHP code generation and reverse engineering (beta release)
     - Code generation templates to support the PHP language
     - Importable standard datatypes package
     - Reverse engineering of PHP
     - Synchronization of PHP source code and syntax highlighting for source editor
Improved transaction handling around XMI import/export and version control check-in and check-out
Modified modality of dialog boxes shown when checking in and out packages to version control to prevent inadvertent interruption of the process
Improved speed of XMI import- especially in removing existing packages from model prior to import
Fixed issue with object Maintenance dialogs which treated name as key value. Also allowed multi-delete in docked list.
Fixed issue in C++ reverse engineering parameterized operation arguments
Fixed Synchronize options for package-level source code generation. Previously, class-level synchronize options were used
Modified RTF export to allow user entered line breaks in operation paramters to appear in documents
Modified behaviour of several dialogs in EA to better handle "Save" operation when initiated by pressing Enter key
Fixed issue with diagram icon in browser not changing immediately a diagram type is changed
Fixed diagram not saving Page Setup when invoked and set from the File menu
Corrected Status Types dialog query definitions for MySQL - problem with case sensitivity
Some minimisation of queries generated when moving diagram elements around to assist those using EA over a slower link
Fixed problem with Add-In menu when switching between user defined visual layouts
Fixed issue with Oracle and Implementation/Dependency report
Updated Scenario dialog behaviour to preserve list selection when a scenario is saved
Changed the default value of the "Show Stereotypes" option in the Options->General page to true
Fixed a gui issue with the attributes dialog that wrongly enabled the property checkbox after clicking the new button to add an attribute.
