Author Topic: Unable to apply stereotype to connectors  (Read 3569 times)
kames
« on: January 23, 2014, 09:25:07 pm »
Hi all,
I have a following problem: I am unable to add a stereotype to an existing association. I can create a new association with a this stereotype no problem (by choosing it in the toolbox and the dragging from one class to another), but a can't add a stereotype to an existing one. If I try to drag the stereotype from the toolbox to the association, nothing happens, and if I open the Properties dialog and set association there (by choosing it in the second popup window), and then click OK, also nothing happens? Could you tell me if I'm doing something wrong, or is it a bug in EA?
I'm using the latest version of EA (10 b1009)
Re: Unable to apply stereotype to connectors
« Reply #1 on: January 23, 2014, 09:44:19 pm »
Do you have security enabled? If so there's an option about managing stereotypes. Without that permission you can only use existing stereotypes.
kames
« Reply #2 on: January 24, 2014, 12:44:33 am »
Thanks, it worked!
