Author Topic: Sequence diagram seems broken  (Read 4713 times)
bergtwvd
« on: January 20, 2014, 09:34:47 pm »
I am using EA 10.0.1008, UML sequence diagram.
When I draw a message from lifeline A to lifeline B, sometimes the message does not appear, but only the rectangle on the receiving lifeline. Or sometimes the message is drawn at the end of the diagram.
When I close and re-open the window, messages seem to appear at the right place again.
However, I cannot move a message up or down, to another place in the sequence diagram.
This looks to be a bug in EA.
bergtwvd
Re: Sequence diagram seems broken
« Reply #1 on: January 25, 2014, 12:27:15 am »
Can this issue be confirmed? This issue prohibits us to create sequence diagrams and a fix or work around is highly appreciated.
-- Tom van den Berg
Maggie
« Reply #2 on: January 25, 2014, 12:34:40 am »
Hi
Not much help, I know, but we do not experience any problems with sequence diagrams
Maybe you should contact sparx support
Maggie
« Reply #3 on: January 25, 2014, 01:01:56 am »
You are using VC, aren't you? Check that you use instances not classes in your SDs.
