Author Topic: Issus on Property Types API  (Read 3310 times)
mv01d
« on: February 24, 2014, 09:09:09 pm »
  • Adding a new Property Type with the following code
var obj = repository.PropertyTypes.AddNew(propertyName, "<memo>");
if (obj != null)
      type = obj as EA.PropertyType;
      type.Detail = "Type=AddinBroadcast;";
      type.Update();
Does not refresh the repository correctly. The new Propery does not triggers a EA_OnConnectorTagEdit call until a re-open of the project. (Tested: EA10 and EA11 beta)
  • The call EA.Repository.PropertyTypes.GetByName(...) leads to the Exception:
System.Runtime.InteropServices.COMException (0x80040002): Action is not supported
  bei EA.CollectionClass.GetByName(String Name)
[/list]
Re: Issus on Property Types API
« Reply #1 on: February 24, 2014, 11:12:31 pm »
I just ran that code and it worked with no issues.
Why should it trigger EA_OnConnectorTagEdit? It is not a new tag, but just a template. And that was entered correctly.
Aaron B
« Reply #2 on: February 25, 2014, 09:19:09 am »
I would not expect adding a new Property type (via automation or the GUI) to trigger EA_OnConnectorTagEdit at all.  That event seems completely unrelated as far as I understand it.
The GetByName function is only supported for use on specific Collections (Model, Package, Element, Diagram, and element TaggedValue).  See:
http://www.sparxsystems.com/enterprise_architect_user_guide/10/automation_and_scripting/collection.html
