Author Topic: Bug: ERROR: syntax error at or near ","  (Read 3908 times)
Rijk J. van Vulpen
« on: March 03, 2014, 08:12:13 am »
I am using PostgreSQL as a database.
When I run a rtf report I receive the error:
ERROR: syntax error at or near ",";
Error while executing the query
If I push OK the scripts will progress it seems
and after many of these errors, the rtf report results
(apparently without failure?)
A colleague of mine gets it when opening
any view/archimate schema I made. Views
open correctly after clicking OK.
Can you help me out?
Re: Bug: ERROR: syntax error at or near ","
« Reply #1 on: March 03, 2014, 09:24:20 am »
If you haven't already, can I suggest that you fill out the bug report form?
Please include the contents of '%appdata%\sparx systems\EA\dberror.txt'  (paste that into your file system explorer bar, run window or open dialog of any text editor)
Rijk J. van Vulpen
« Reply #2 on: March 04, 2014, 12:46:04 am »
Will do. Found bug and solution, see below.
    Select * from t_xref where  Type ='swimlane' and Client='{E7EB60AE-7120-4db7-9448-56D64B1401A0}' order by to_number(Partition, '99999999999999999999999')
Solution:
9448-56D64B1401A0}' order by to_number('Partition', '99999999999999999999999')
the function to_number expects two 'text' parameters aka the Partition parameter has to escaped by single quotes.
Cheers
