Author Topic: t_objectresource.resource issue  (Read 4152 times)
Marianne
« on: April 14, 2014, 07:38:58 pm »
if I run the query 'select * from t_objectresource' one of the fields I get is 'Resource' (in uppercase for first letter, the rest lowercase)
I want to run a query like this:
SELECT  t_objectresource.Resource,   t_objectresource.PercentComplete, count(*)
FROM t_object, t_objectresource
WHERE t_object.Object_ID=t_objectresource.Object_ID AND t_object.Phase='1.1'
GROUP BY  t_objectresource.Resource,  t_objectresource.PercentComplete
But then I get the error ORA-01747: invalid user.table.column, table.column, or column specification.
I tried name instead of resource but it doesn't work either.  :(
Thanks for your help!
Helmut Ortmann
Re: t_objectresource.resource issue
« Reply #1 on: April 14, 2014, 07:46:39 pm »
I tried it with *.eap (JET 4) and SQL Server. It works fine.
Helmut
« Reply #2 on: April 14, 2014, 09:45:04 pm »
Try the SELECTs single to find what's wrong. E.g.
SELECT * FROM t_objectresourcethen
SELECT  Resource FROM t_objectresourceetc.
to see where it fails.
« Last Edit: April 14, 2014, 09:45:33 pm by qwerty »
hd
« Reply #3 on: April 15, 2014, 07:42:05 am »
Resource is an Oracle keyword. Wrap it in double quotes...
SELECT  "Resource" FROM t_objectresource
