Author Topic: EA - issue with code engineering and MySQL 5.0  (Read 3817 times)
GW
« on: April 15, 2014, 11:54:48 pm »
Hello there,
I work with Enterprise Architect version 9.2.922.
My project is a data model with some tables, triggers and one stored procedure.
I use the menu "Code engineering / generate DDL" to generate the whole DDL in a single file and I run it in MySQL. v5.0.
All works fine except the stored procedure.
EA automatically add the delimiter around the procedure with "DELIMITER //" at the top and "//" at the end.
That's a good thing but EA add also a semi colon ";" after that and MySQL does not accept this extra semi colon, it says :
"ERROR 1065 (42000) at line x: Query was empty".
Does anyone knows a way to change the behavior of EA so that the generated procedure does not end with a semi colon ";", but only with the specific delimiter "//"  ?
