Author Topic: Renamed param but on code generation still newVal  (Read 4174 times)
sergeda
« on: April 19, 2014, 06:17:56 pm »
Hello.
After renaming param for function on PHP code generation I've got:
     public function setCreated_by($data)
            $this->Created_by = $newVal;
Where "data" is the new name for param. Why still newVal in the function?
Re: Renamed param but on code generation still new
« Reply #1 on: April 19, 2014, 06:29:24 pm »
Probably because it's code which is not really interpreted by EA. You would need to correct the code body manually.
sergeda
« Reply #2 on: April 19, 2014, 06:56:23 pm »
But code generated based on some rules and if it used correct param name in one place I think it shouldn't be problem to use it in another place. To me it looks like a bug.
« Last Edit: April 19, 2014, 06:56:58 pm by sergeda »
« Reply #3 on: April 19, 2014, 11:29:33 pm »
It's like a one way. Code being generated is just spit out, never read back. Only the class definition is read by EA.
« Last Edit: April 19, 2014, 11:29:45 pm by qwerty »
sergeda
« Reply #4 on: April 20, 2014, 02:50:25 am »
Thanks for info.
Nizam Mohamed
« Reply #5 on: April 21, 2014, 03:08:43 pm »
Have you tried using String concat
something like
$sOpCode1 = "$this->Created_by" + "=" + $newVal
$sOpCode1
