Author Topic: EAP files on SharePoint  (Read 6307 times)
Fabian Knoll
« on: April 18, 2014, 07:51:37 pm »
I have placed the EAP file on Microsoft-SharePoint. If I am using the windows explorer (not the internet explorer) to work on the SharePoint directory, I can't open the EAP file. Enterprise Architect stops opening the file with an error message: "Coudln’t lock file".
Does anyone know a solution for that issue?
Regards
Fabian
Re: EAP files on SharePoint
« Reply #1 on: April 18, 2014, 10:36:47 pm »
The solution is: Do not put .eap files in Sharepoint.
A .eap file is an Access database. You don't put databases on sharepoint.
Fabian Knoll
« Reply #2 on: April 22, 2014, 06:44:47 pm »
Hi Geert,
thanks for your reply. I understand your point of view to "do not put databases on SharePoint" but if I am using SharePoint in this case only as a file share it should be ok. Also putting EAP files on file shares (e.g. windows file shares) is an recommendation of Sparx for small groups.
Fabian
« Reply #3 on: April 22, 2014, 11:05:21 pm »
The thing is that it will try to create a "hidden" ldb file in the same directory, and sharepoint might object to that.
Fabian Knoll
« Reply #4 on: April 22, 2014, 11:07:22 pm »
Thats a good point, thank you!
Fabian
