Author Topic: Not able to remove business rules from Use Case  (Read 18295 times)
AA Mamun
« on: May 19, 2014, 02:40:29 pm »
We are facing problem with removal of business rules from use cases in Enterprise Architect. When a business rule is linked as dependency with any use case, it cannot be removed later. Deletion of link between particular business rule and use case is not working.
Nizam Mohamed
Re: Not able to remove business rules from Use Cas
« Reply #1 on: May 20, 2014, 02:18:43 pm »
Hope you've tried deleting it from the "Links" tab of the usecase properties dialog.
(External rules / requirements cannot be deleted from the 'requirements' tab of the usecase)
