Author Topic: Notes input to describe database format issue  (Read 9545 times)
Wolf K
« on: May 21, 2014, 05:20:41 am »
I am using EA to document my database dictionary.  The output for my customer is a generated RTF document.  In order to add sufficient field descriptions I use the 'Notes' field for the field element.  However, the format options are not really sufficient to document a field properly.  For example: I try to copy and paste a small table into the notes field (from Word) and all formatting is immediately lost.  Is there a way to have EA support better formatted notes?
Re: Notes input to describe database format issue
« Reply #1 on: May 21, 2014, 06:41:38 am »
I wish
and good luck with that (see Memo tags allow rich text please )
At a minimum please submit a feature request
« Reply #2 on: May 22, 2014, 08:42:08 am »
The recommendation is to use a linked document if you want tables as part of your notes.
Wolf K
« Reply #3 on: May 23, 2014, 04:41:12 am »
I don't understand this suggestion.  I have about 100-150 feature classes and tables in my model with at least (estimate) 10+ attributes (columns) for each.  I want to print out a data dictionary for my customer and I in the data dictionary I want to show in the 'notes' column my 'formatted' explanation for that field.  You are suggesting that I add a 'linked' document, I am not sure how that would help me.  In essence I am writing my data dictionary now outside EA.  I thought EA would allow me to single source my efforts.
« Reply #4 on: May 23, 2014, 05:20:31 am »
Actually that is exactly what Simon suggests. You may consider to use automation to create the linked documents.
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« Reply #5 on: May 23, 2014, 06:11:41 am »
But linked documents exist per class/table (element), not per attribute/colum as required in this case.
« Reply #6 on: May 23, 2014, 06:56:48 am »
Sure. So you have to create a more (or less) complex document inside the class which knows about the contained attributes. We all know it's crap but you likely can't hope for a meaningful solution in time.
Wolf K
« Reply #7 on: May 23, 2014, 10:18:27 am »
This is getting pretty complicated for a relatively simple task.  It looks like I am back to maintaining a separate data dictionary in word.  Unfortunately my customer insists that I add various business rules that affect most columns to the data dictionary, and the notepad style formatting supported by EA is not sufficient for this task.
« Reply #8 on: May 23, 2014, 01:08:32 pm »
Woolf, get yourself and 100 of your friends, and all the EA trainers you know to each submit a feature request. You might get it by christmas, especially if your 100 friends are all EA trainers.
