Author Topic: New Toolbox based on BMN2.0  (Read 4432 times)
Munich
« on: May 28, 2014, 01:14:24 am »
I am trying to configure a new toolbox based on BPMN 2.0 Elements.
Unfortunately I am not able to position start, intermediate and end events into my diagram. Presumably the stereotypes "BPMN2.0::Start Event", "BPMN2.0::Intermediate Event", "BPMN2.0::End Event" are not correct".
Any help would be highly appreciated.   :)
Best regards from Germany
Re: New Toolbox based on BMN2.0
« Reply #1 on: May 28, 2014, 08:41:39 am »
I think you'll need to recreate the hidden toolboxes that are used to show the popup menus for those types.
Munich
« Reply #2 on: May 28, 2014, 04:06:01 pm »
Hi Simon,
thank you for your fast answer. Why do "events" behave differently from "gateways"? Reusing a BPMN-gateway within my customized toolbox was no problem - the hidden menu shows up.
Anyway . I tried your advise and this still doesn't work. Could you please confirm the exact BPMN2.0 syntax which is used in EA? What would be the name of the sub menu - I tried with BPMN2.0::End Event for the stereotype and e.g. BPMN2.0::Edge-mounted(BPMN2.0::End Event) for an attribute?
I appreciate your help.
Best regards
Jens
« Reply #3 on: May 28, 2014, 04:54:59 pm »
Try putting BPMN2.0::EndEvent(UML::Event) and BPMN2.0::EndEvent(UML::ObjectNode) directly into your toolbox (don't worry about sub-menus to begin with)
« Last Edit: May 28, 2014, 04:55:22 pm by KP »
Munich
« Reply #4 on: May 28, 2014, 05:19:57 pm »
thank you very much for your help. I am able to position the events now.
Just annother issue. I ahev realized, that the BPMN Quick Linker are not showing up. How can I resolve this?
Thank you.
Best regards
Jens
« Reply #5 on: May 29, 2014, 09:36:26 am »
The BPMN 2.0 quicklinks are defined to only apply on BPMN 2.0 diagrams. (This was done to prevent conflict between different versions of BPMN - doesn't really help you though)
