Author Topic: sysml required admin rights  (Read 4264 times)
MichaelB123
« on: June 19, 2014, 12:46:39 am »
I've installed EA 10 and the SYSML plugin successfully on a machine where I have Administrator privileges.
However, although it install fine, the SYSML plugin isn't available on a Win 7 machine where I don't have admin rights. When an IT support person logs on using their admin credentials it appears, but not for a "normal" account.
Is there any way around this?
Michael
Re: sysml required admin rights
« Reply #1 on: June 19, 2014, 06:46:21 am »
AFAIK this has to do with the registry keys being in local user rather than local machine. You could copy them manually. I don't remember which keys that were, but a look into the registry might enlighten you. Or some humble other reader of this forum.
« Reply #2 on: June 19, 2014, 09:05:15 am »
As another alternative.
The only purpose the SysML add-in generally serves is to enable the SysML functionality built-in to EA. (It provides SysML 1.0 itself, but EA supports up to SysML 1.3)  In EA 11 you no longer need to install the add-in at all to get the functionality. You just need to add your license key.
MichaelB123
« Reply #3 on: June 23, 2014, 06:40:17 pm »
Thanks both very much for your reply.
I still have approx 4 months left of my EA 10 license - does this mean I'm entitled to upgrade to EA 11 at no extra cost?
Thanks again,
Michael
« Reply #4 on: June 23, 2014, 07:34:20 pm »
And the answer is: yes.
