Author Topic: Project Menu - Resources option missing  (Read 3385 times)
k2901
« on: June 30, 2014, 10:04:07 pm »
I'm using the latest EA v11 Build 1107 and for some reason, the Resource menu option is not listed. I've reloaded EA and reloaded the EAexample project, no change i.e. the Menu option is not shown.
Any ideas anyone?
Re: Project Menu - Resources option missing
« Reply #1 on: June 30, 2014, 11:47:22 pm »
Check View/Workspaces/Commands and tick all options.
k2901
« Reply #2 on: July 01, 2014, 12:03:22 am »
Thanks for the tip. I've tried make all the commands ticked as you've suggested. After I've added the ticks to the options, EA that resaves the changes with a new COmmand set name. So not sure if it will pickup the changes. Also, can't see a specific option for the Resources menu option under Project Menu. So still got the prblem.
k2901
« Reply #3 on: July 01, 2014, 12:13:04 am »
Think I've solved it now. Select the (copy of exisiting workspace layout) command set and then go into Commnds and apply all the ticks needed. Then save this as a new set and EA will create a custom set with the "ticks" enabled as you've requested. Hpe that makes sense. All sorted thou. Still can't understand how what the relationship is between custom command set names and menu options, especially when you can't update the command sets that are there!
