Author Topic: Language Macros for C  (Read 5692 times)
andreas_w.
« on: July 01, 2014, 07:27:43 pm »
I work with EA version 10.0.1004. I have synchronized some C source to my EA repository. I see that EA has set on operation level a tagged value called DeclMacro1 with the value __inline, which is fine. :)
I believe I must set this value as preprocessor macro for the language C. I choose the menu "Setting-->Preprocessor Macros ..."  and I get the dialog "Language Macros". I see the default language is C++, but I'm not able to select C.  :-?
The code generation doesn't take the __inline value into consideration.  :(
Re: Language Macros for C
« Reply #1 on: July 02, 2014, 10:19:56 am »
C++ and C are sharing the macros.
andreas_w.
« Reply #2 on: July 02, 2014, 10:25:44 pm »
Thanks for you clarification.But I have now some doubts which I would like to describe.
1. I have in "C" a method declared like this:
 static __inline void acq_lock(TP_Thread_Data_T *thread_data)
2. I synchronize the file with EA and I find a operation with a tagged value called DeclMacro1 and the value __inline :)
3. I define in the Language Macros dialog the value __inline  :)
4. When I generate the UML class as C source I get static void acq_lock(TP_Thread_Data_T *thread_data), without the __inline  :(
5. When I generate the UML class as C++ source I get static __inline void acq_lock(TP_Thread_Data_T *thread_data) with __inline :-?
What shall I change that it works for step 4 with the C language ? Every hint is very welcome.
« Reply #3 on: July 03, 2014, 08:54:49 am »
I'm not sure.
I looked at the template for Operation Declaration, expecting to find %opMacros% missing, but everything is in order.
Would it be safe to assume you haven't modified the templates?
« Last Edit: July 03, 2014, 08:55:17 am by simonm »
andreas_w.
« Reply #4 on: July 03, 2014, 04:00:30 pm »
I believe, I have use the default "Operation Declaration" template for C as language.
The %opMacros% is in, but because the operation is static the %opMacros% isn't reached.
I get the __inline, if I deactivate the static check box.
This is the snipped:
%PI=" "%
%if opTag:"define" == "true"%
#define %opName%(%list="Parameter" @separator=", "%) %opCode%
%endTemplate%
%if opStatic=="T"%
%endTemplate%
%opConst=="T" ? "const" : ""%
%opReturnType%
%opMacros%
%PI=""%
$bodyLoc = %opTag:"bodyLocation"%
%if opTag:"inline" != "true" and $bodyLoc != "header" and $bodyLoc != "classDec"%
%endIf%
I'm not a C expert, are there good reasons for this static exclusion?
%if opStatic=="T"%
%endTemplate%
