Author Topic: EAvs11 adding tagged values of 2 UML profiles  (Read 4484 times)
Remko
« on: June 12, 2014, 07:31:02 pm »
We use 2 different UML profiles to add specific Tagged Values while making an information model. We used vs9.3 and we are now testing vs11. We imported the 2 UML profiles (alt+6), let's say Profile_A and Profile_B. We first imported Profile_A and then Profile_B. When we add an item from Profile_B EnterpriseArchitect apparently also adds the tagged values from Profile_A. (But not vice versa.)
This also influences are reports (with wrong output).
We never experienced this in vs9.3. Does anyone have a clue why this happens and what we can do about it?
« Last Edit: June 12, 2014, 08:18:40 pm by RemkodeHaas »
Re: EAvs11 adding tagged values of 2 UML profiles
« Reply #1 on: June 12, 2014, 07:33:24 pm »
Hard to tell without knowing details about your 2 profiles.
Remko
« Reply #2 on: June 12, 2014, 07:53:55 pm »
thanks for your quick response.
what information should i add to clarify about the uml profiles?
« Reply #3 on: June 12, 2014, 09:12:05 pm »
Well, I don't know. Are you using different identifiers? How are your 2 profiles related to each other?
« Reply #4 on: June 13, 2014, 08:51:30 am »
"When we add an item from Profile_B" -- how are you doing this? what are the keystrokes and mouse clicks/drags?
Do the two profiles have stereotypes with the same name?
What you appear to be describing is not anything I have seen, so please describe in enough detail that I or anyone else can reproduce the problem and see it with our own eyes. Thanks!
EDIT: Are you using a Project Template Package?
« Last Edit: June 13, 2014, 08:56:02 am by KP »
Remko
« Reply #5 on: July 07, 2014, 08:24:44 pm »
thank you both for your responses. Some stereotypes in the 2 profiles have the same name. That seems to be the problem.
