Author Topic: Remove MDG technology  (Read 16360 times)
anna.szucs
« on: July 10, 2014, 05:41:05 pm »
Hello
I need help.
How can I remove my MDG file from EA'a MDG dialog?
I made MDG technology, I imported it, and I used it.
But sometimes my technology XML file hides from EA/MDGTechnologies library, but I can see it from EA MDG technology dialog.
I imports (or copies) it again but now I can see my MDG technology 2 times in the MDG tech. dialog and so on.
Now I can see my MDG technology 4 times and it troubles me!
I found simple solutions: remove MDG files from MDGTechnologies library but i does not work. My file is not in folder but I can see in EA's MDG technology dialog.
Re: Remove MDG technology
« Reply #1 on: July 10, 2014, 06:26:10 pm »
Just delete the source file. It's either where the Advanced setting in the MDG dialog shows or under EA Program directory in the MDG sub-folder.
If both is not the case look in the Project Resource window where it might have been imported for the project statically.
« Last Edit: July 10, 2014, 06:27:14 pm by qwerty »
anna.szucs
« Reply #2 on: July 10, 2014, 08:49:01 pm »
Thanks your reply!
1.MDG Technology/WebDP MDG/Advanced setting were empty every MDG of mine.
After I add path to my first MDG. After I can see new path the other WebDP MDG too. After I remove the path from my first item (it has done automkatically the others too).
Nothing has changed! I can see 4 WebDP MDG tech in EA MDG technology dialog.
2. in Resource window, there isn't anything under MDG technology.
I have tried every solution what I found on the internet but nothing worked.
I do not understand that too EA why do not update my MDG file why showing as a new MDG technology.
I think there is a sort of relation between my items and I have to remove it from file directly. I have looked over every EA phisycal file but I did not find any reg, property or similar file.
« Reply #3 on: July 11, 2014, 05:15:30 am »
You did not tell us about the Programs folder. The Sparx EA program folder has a sub-folger MDG Technologies (I'm off-site and writing by heart) where EA also looks for MDG files.
« Reply #4 on: July 11, 2014, 09:26:17 am »
Also look in %APPDATA%\Sparx Systems\EA\MDGTechnologies
« Last Edit: July 11, 2014, 09:26:41 am by KP »
anna.szucs
« Reply #5 on: July 11, 2014, 04:40:11 pm »
Thanks, the answers for everybody!
I wrote, I looked for my WebDP MDG tech. .xml files in MDGTechnologies library too but there aren't any WebDP file althought I can see my MDG tech files in EA MDG technology dialog window.
That is why I am puzzled.  :-/
I am looking for such sulotion what I can not find on internet, because I tried most of them but did not worked neither of them.
« Last Edit: July 11, 2014, 04:41:09 pm by anna.szucs »
« Reply #6 on: July 11, 2014, 04:48:26 pm »
From the main menu, go Settings > MDG Technologies. In the MDG Technologies dialog, select your technology. Now look over on the right-hand side of that dialog and where it says "Location:", what does it say after that?
anna.szucs
« Reply #7 on: July 11, 2014, 05:06:12 pm »
Something new, thanks!  :D
It is interesting, because the location is different of each my MDG tech.
1. WebDP MDG - Location: WebDpTool MDG.
Here I can not see any library (?) only file name
2. WebDP MDG - Location: WebDp MDG.xml (in APPDATA)
Maybe this refer to the %APPDATA%\Sparx Systems\EA\MDGTechnologies (?)
3. WebDP MDG - Location: WebDpTool MDG.xml (in APPDATA)
4.WebDp extends - WebDP_MDG.xml (in APPDATA)
You can see from the list my MDG files lifecycle  :o
Maybe after I made some altering in main data of MDG tech.file, it seemed as a new MDG tech. file. (?)
« Last Edit: July 11, 2014, 05:07:25 pm by anna.szucs »
« Reply #8 on: July 15, 2014, 10:07:25 am »
To look in APPDATA, open Windows Explorer and type %APPDATA% in the address bar
anna.szucs
« Reply #9 on: July 15, 2014, 04:49:11 pm »
Thank you for your help! :D
Yesteday I tried: I remove all files (not only mine) from c:\Program Files\Sparx Systems\EA\MDGTechnologies\, so the library was empty.
I run EA and I also find 3 WebDP items in MDG tech.dialog.  >:(
After I run REGEDIT, and I found lot of WebDP::xxxx class definition (for EA) I deleted it.
Nothing was changed.  >:(
(Of course after I copied back MDG tech. to APPLIB except mine.)
I think something went wrong in my EA's soul  :o and I try to find it but I can not yet.
« Last Edit: July 15, 2014, 04:50:19 pm by anna.szucs »
adama
« Reply #10 on: January 27, 2017, 01:22:56 am »
This worked for me. THanks.
