Author Topic: Difference between Package and View  (Read 4364 times)
Tehila1
« on: July 27, 2014, 07:37:47 pm »
I use the built-in search for getting checked-out packages for me.
It works fine for checked out packages, as opposed to checked out view;
a checked out view doesn't appear in the search result unless there is currently  also a checked out package in the model.
 Have someone encountered this bug?
Re: Difference between Package and View
« Reply #1 on: July 28, 2014, 09:08:25 am »
Could you post your SQL? I don't think there's a big difference between view and package.
« Last Edit: July 28, 2014, 09:08:42 am by qwerty »
Tehila1
« Reply #2 on: July 28, 2014, 06:54:03 pm »
The SQL I copies from the built-in search for checked out packages:
SELECT
t_object.ea_guid AS CLASSGUID, t_object.Object_Type AS CLASSTYPE,t_object.Name AS Object, t_object.Object_Type AS [Type], t_object.Stereotype, t_object.Scope,t_object.Status, t_object.Phase, t_object.CreatedDate, t_object.ModifiedDate
FROM
t_object, t_package
WHERE
t_object.Object_Type='Package'
AND
#DB=Other#t_object.PDATA1 = cstr(t_package.Package_ID)#DB=Other#
#DB=ORACLE#t_object.PDATA1 = to_char(t_package.Package_ID) #DB=ORACLE#
#DB=OPENEDGE#cast(t_object.PDATA1 as char(25)) = cast(t_package.Package_ID as char(25))#DB=OPENEDGE#
#DB=ASA#t_object.PDATA1 = cast(t_package.Package_ID as char)#DB=ASA#
#DB=SQLSVR#t_object.PDATA1 = cast(t_package.Package_ID as char(25))#DB=SQLSVR#
#DB=MYSQL#t_object.PDATA1 = t_package.Package_ID#DB=MYSQL#
#DB=POSTGRES#t_package.Package_ID = t_object.PDATA1::text::int#DB=POSTGRES#
AND
t_package.PackageFlags LIKE '#WC#VCCFG=#WC#CheckedOutTo=#UserName##WC#'
Something wrong?
« Reply #3 on: July 29, 2014, 06:15:05 am »
I just tried that query and it returned package as well as view. Which RDBMS are you using?
Tehila1
« Reply #4 on: July 29, 2014, 06:31:11 pm »
The model is Oracle based.
Did you try the query in case there are only view checked out, with no package?
« Reply #5 on: July 29, 2014, 07:06:14 pm »
Yes (once you said it). And the result is still correct. I don't have Oracle (just using EAP) so someone else would need to verify that. Anyhow, I would not see why Oracle would not work wrongly as opposed to other RDBMS. Maybe you could send a bug report. I suppose there is another reason for the behavior. Sparx support is quite helpful when it comes to such issues.
