Author Topic: Search results with Packages : issue  (Read 4183 times)
Guillaume
    • www.umlchannel.com
« on: July 25, 2014, 11:34:42 pm »
I've created a custom search (SQL) using the Builder.
here is a simplified version to test :
SELECT ea_guid AS CLASSGUID,  name as Package from t_package
I use CLASSGUID so that EA can find my Package in the Project Browser.
However when I right click on a result from the list, Find in Project Browser is disabled.
This is odd since the keyboard shortcut Alt-G works... I can also access the Package's properties when I double click onto it.
Is this a bug?
« Last Edit: July 25, 2014, 11:37:29 pm by gfuk »
Guillaume
Helmut Ortmann
Re: Search results with Packages : issue
« Reply #1 on: July 26, 2014, 01:52:27 am »
Hi Guillaume,
you have forgotten to define the type (CLASSTYPE):
SELECT ea_guid AS CLASSGUID, 'Package' AS CLASSTYPE,  name as Package from t_package
Consider using t_object (depends what you want to know):
SELECT ea_guid AS CLASSGUID, object_type  AS CLASSTYPE,  name, stereotype
from t_object
where object_type = 'Package'
Helmut
Guillaume
« Reply #2 on: July 30, 2014, 09:52:28 pm »
Thanks Helmut. I wasn't sure I could use "classtype".
I managed to get it to work and published my user defined search alongside an illustration in the following article:
http://www.umlchannel.com/en/enterprise-architect/item/108-sparxsystems-enterprise-architect-user-defined-search-to-find-a-controlled-package-based-on-the-xmi-filename-path
Guillaume
