Author Topic: PROBLEM ODBC INVALID OBJECT NAME SYSPROPERTIES  (Read 5619 times)
Moy
« on: August 15, 2014, 02:18:11 am »
hi therefirst time using this software i should import a database from sql server and i have already created the ODBC source, then on the package right click Import DB from ODBC schema , i mark the right options in dialogbox then after i select to import all of the tables i got this error message ODBC SQL SERVER DRIVER Invalid object Name 'Sysproperties'
THANK YOU I WILL APPRECIATE YOU HELP!!
Re: PROBLEM ODBC INVALID OBJECT NAME SYSPROPERTIES
« Reply #1 on: August 15, 2014, 06:11:31 am »
Same question as always: checked privileges? The more the better....
« Last Edit: August 15, 2014, 06:11:44 am by qwerty »
