Author Topic: Problems with EA 9.1  (Read 8444 times)
bam bam 666
« on: August 16, 2014, 03:34:40 am »
from this week I'm having troubles with my  models all rady done, when I tried to opened my laptop crash and have to rebbot, I gess it's because a windows security update,
How can I fix this problem, Do you have any patch to fix it ???
Regards  :)
Re: Problems with EA 9.1
« Reply #1 on: August 16, 2014, 06:32:42 am »
I bet t hasn't to do with EA. EA is a program like any other program (e.g. Notepad) and does not tangent any security issues. Two things to do: a) check for viruses or the like. b) re-install EA. And a third thing: explain in more detail what happens when you try to open EA.
As a side node: maybe it's just you can't write well in English. There's a chance someone can translate from your native language (it it's not some too strange dialect). So eventually post in both your language and in English. But as long as you can read well it's okay this way :)
« Reply #2 on: August 18, 2014, 08:51:55 am »
Unfortunately Microsoft released a couple of bad patches last week. Last I read the advice from Microsoft was to uninstall them.
Edit: See http://www.zdnet.com/microsoft-pulls-updates-recommends-uninstall-7000032678/ for the list of problem patches.
« Last Edit: August 18, 2014, 08:54:22 am by simonm »
AndyJ
  • It's only a model
« Reply #3 on: August 18, 2014, 03:18:30 pm »
I bet it hasn't to do with EA.
I always blame Microsoft first, this often saves a lot of time...
When it doesn't, I still get to blame Microsoft, which I enjoy.
« Reply #4 on: August 18, 2014, 06:39:04 pm »
I always try to get rid of a patch which is called Microsoft Windows which was released for MS DOS.
« Last Edit: August 18, 2014, 06:39:16 pm by qwerty »
ICTFox
« Reply #5 on: August 18, 2014, 06:56:44 pm »
We have seen issues with EA11 in combination with MS14-045, specifically KB2982791. As per Microsoft advice we have removed the update from the systems. Very likely the issue with your version is the same, as the issue relates to the updates win32k.sys module.
AndyJ
  • It's only a model
« Reply #6 on: August 19, 2014, 09:29:21 am »
Ah qwerty!
You have reminded me of a favourite joke from the old days...
"I can make your computer run 100 times more efficiently with a simple DOS command!"
"How?"
"Go to the C:\ prompt, and type: deltree \windows"
 ;D
Seriously people, don't do this. (Just in case deltree is still in the CMD DOS emulator)
« Reply #7 on: August 19, 2014, 09:31:48 am »
I think what you want is rmdir /s /q C:\Windows
Of course, I don't advocate this as Windows is the best way to run my favourite software.
Out of curiosity, I tried it on a VM. The command failed but was enough to prevent windows from booting.
« Last Edit: August 19, 2014, 11:21:11 am by simonm »
AndyJ
  • It's only a model
« Reply #8 on: August 19, 2014, 09:41:30 am »
Yes...
I believe that there was a relatively recent post which explained that there will never be a version of EA for linux...
« Reply #9 on: August 19, 2014, 11:24:45 am »
To be more precise. I can't see a situation where a native linux version of EA would be economically viable. So the word never would only apply if under the assumption that my imagination is perfect and Sparx Systems is always going to be concerned with making profit.
AndyJ
  • It's only a model
« Reply #10 on: August 19, 2014, 11:26:39 am »
I understand. I really do.
But I'm still sad about it. :(
RoyC
  • Read The Help!
« Reply #11 on: August 19, 2014, 03:01:13 pm »
Your penguin looks quite despondent too.
Best Regards, Roy
