Author Topic: Installing and configuring WAN Optimizer  (Read 5467 times)
gnavarruiz
« on: February 01, 2014, 06:49:58 am »
Hi
I need one explication about the procces of installing and configuring this outil WAN Optimizer.
I follow the steps indique but when I will open my Enterprise Architect i see one error
''WAN OPTIMIZER: Server Error - There is no database manager configured for the requested repository''
Thanks four your help
gnavarruiz
Re: Installing and configuring WAN Optimizer
« Reply #1 on: February 01, 2014, 06:55:37 am »
Sam Courtney
« Reply #2 on: February 01, 2014, 09:23:30 am »
Have you followed the steps in the WAN Optimizer Uzer Guide, and looked at the log file after the install?
Have you filed this with Tech Support?
« Last Edit: February 01, 2014, 09:25:08 am by scpag »
« Reply #3 on: February 03, 2014, 08:34:11 am »
Open the WAN optimizer manager.
In the list of databases select the relevant database manager and click configure.
Click the checkbox 'Accept Queries'
EA should now connect.
gnavarruiz
« Reply #4 on: February 04, 2014, 01:30:15 am »
Hi
Thanks for the advance.
There is not working, I followed all the suggestions but i don't know why this not working.
This is my screen picture
https://mega.co.nz/#!YgoHBLoL!qA78sg8_wXeASz72cNwDnaXfridfiEo_TWOIbYCiwQE
Thanks again for your help.
Sorno
« Reply #5 on: September 04, 2014, 07:58:21 pm »
Make sure that the connectionstring is naming the databases with lower case.
If you use the connection wizard in EA the connection string will get the same case as the databases is actually named. In WAN opimizer though the name will be just lower case. Since the comparison of connection strings is case-sensitive it will thus not match.
